| Author |
[Modern View]
| ldj
09-27-2012 20:17:14
64.123.133.193
I bought an electric fuel pump for a lawnmower. It worked about an hour and quit. I am selling it on ebay, however I don't think anyone will want it. Below is link to the listing so you can read it and decide if you want one like it from that seller. http://www.ebay.com/itm/280980577782?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649 |
| barnE
09-29-2012 18:18:59
67.172.83.183
Re: Electric fuel pump in reply to ldj, 09-27-2012 20:17:14
| Do not tie pump wiring into ignition coil. If ign ition has a ballast resistor in use, pump will be starving for current. Also probably not work at all or correctly. How do I know. Experience long time ago with Renault Dauphine car. Found out after rebuilding motor. This faulty hook up was the only problem. Never made that mistake again after 1966. Dave |
| JeremyR
09-29-2012 06:10:22
97.89.154.252
| Have you checked your voltage coming to to the pump checked for a blown fuse. What kind of mower are you using it on. |
| ldj
09-29-2012 15:12:46
64.123.133.193
Re: Electric fuel pump in reply to JeremyR, 09-29-2012 06:10:22
| Yes I checked all that before saying pump was bad. I bought another pump and it works good---so far. It is on a Kohler M20 on a snapper zero turn. |
| el6147
09-28-2012 06:34:47
50.36.89.235
| any one else notice what retailer of automotive equipment was advertising on the the same ebay page , one of the largest retailers of china manufactured equipment in the US! "making it affordable for everyone to have a auto lift at home for oil changes on there american UAW built truck" |
| timcasbolt
09-28-2012 04:31:24
72.23.207.250
| Pardon my ignorance, but what difference does it make if it's on a lawn mower or some other application? |
| Billy Shafer
09-29-2012 07:26:01
173.184.43.42
Re: Electric fuel pump in reply to timcasbolt, 09-28-2012 04:31:24
| All depends on voltage and fuel pressure output. On most small engines. Anything over 4 PSI will open the needle valve and cause flooding. |
| bill mart
09-28-2012 05:59:14
69.204.65.189
| MarkB_MI
09-28-2012 02:10:15
75.219.106.174
| A similar Facet fuel pump will set you back at least 50 bucks. That Herko cost you $15. |
| rusted nuts
09-28-2012 01:50:41
98.20.244.84
| Why don"t you just take the thing back to where you got it? Only way they are going to stop building this crap is for us to return it. |
| jammison
09-27-2012 20:20:52
72.181.173.171
Re: Electric fuel pump in reply to John T, 09-27-2012 20:17:14
| Quoting Removed, click Modern View to seeWhat?!!!!!!!! Youm think there are 2 suckers in the world? :arrow: |
