Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: Chevy 1500 Wheel Studs
[Return to Forum]
MCL
09-05-2012 04:16:05
216.21.177.239
My son has a 1998 Chevy 1500 4x4. This weekend the left front wheel lug nuts worked loose and broke off two studs. How hard is it to get to the hub and change the studs? I am replacing all 6 and the nuts also. We had this wheel off recently and must obviously not have gotten it tight enough.
Thanks.
[Reply]   [No Email]
MCL
09-06-2012 13:41:29
216.21.177.239
 Re: Chevy 1500 Wheel Studs in reply to MCL, 09-05-2012 04:16:05
Thanks for the info. Got it done. Ended up taking the hub off and using a neighbor's press to put in the new studs. Drove it about 20 miles and retightened everything. Nothing was loose. Will keep an eye on it for a while though. Thanks again.
[Reply]  [No Email]
ASEguy
09-05-2012 19:12:15
68.186.162.134
To add to what Tom posted, if the 60 degree taper is damaged on the wheel, the wheel will probably come loose again. The 60 degree taper on the lugnut locks the wheel to the hub provided the 60 degree taper on the wheel is not badly damaged. Hope this helps. Gerard
[Reply]  [No Email]
hd6gtom
09-05-2012 10:16:36
75.170.237.148
If it has aluminum wheels they MUST be retorqued every time you remove a wheel, even if you torque them to the proper setting. If it is an aluminum wheel make sure the bolt holes in the wheel are not egged out. If they are the wheel is not usable. Check the back side of the wheel and make sure it is straight, not wallowed.
[Reply]  [No Email]
glennster
09-05-2012 05:48:16
75.57.143.173
not bad to do. pull the caliper and rotor. there should be one position for the hub that you can drive the studs out one at a time. get a few extra lug nuts and a couple flat washers and you can use them to pull the new studs in. when mounting the rim torque them to 75 lbs. re-torque them at 25 miles, 50, and 100. to make sure all are seated correctly. alloy wheels need to be checked up to about 500 miles, as they do have a tendency to loosen up more than a steel wheel until fully seated.
[Reply]  [No Email]
willie in mn
09-05-2012 09:01:47
67.142.168.25
 Re: Chevy 1500 Wheel Studs in reply to glennster, 09-05-2012 05:48:16
My 97 GMC should be the same. Book says torque to 140# for C/K 1500 & 2500, 175 on 3500 series.
Willie
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
