| Author |
[Modern View]
| dhermesc
09-04-2012 09:53:53
24.248.193.103
I borrowed one from my brother - brand new never used. Similar to the ones TSC sells (50# pot). Any idea how to get these to work?I tried it with the valve at the bottom of the tank wide open, partially open and nearly shut - all it did was clog up after a few seconds. I tried bigger and smaller nozzels - no change - clogged after a few seconds of operation. |
| Dave Sherburne NY
09-05-2012 09:40:23
74.32.164.55
Re: Cheap sand blasters in reply to dhermesc, 09-04-2012 09:53:53
| How much pressure have you got?? |
| dhermesc
09-05-2012 11:20:36
24.248.193.103
Re: Cheap sand blasters in reply to Dave Sherburne NY, 09-05-2012 09:40:23
| 150 PSI with a 30 gallon tank. Didn't ever operate long enough to even find out of the the pump could keep up or not. |
| huntingreen2day2
09-04-2012 19:17:13
75.131.120.19
| It is my understanding all sand has some silica in it. |
| Dave Sherburne NY
09-04-2012 12:37:26
74.32.165.153
| The only sand I could get to go thru mine was the finest grade of Black Diamond or playsand. Guys on here say not to use playsand so I don't can't remember the reason think it was something called silicosis from the dust. |
| dhermesc
09-05-2012 05:51:33
24.248.193.103
Re: Cheap sand blasters in reply to Dave Sherburne NY, 09-04-2012 12:37:26
| I tried the black diamond the the silica sand - neither worked more than a second or two. The only time it seemed to work much at all was when I completely removed the valve on the end of the hose and sprayed with a 1/4 opening. |
| rustyfarmall
09-04-2012 13:31:33
67.55.162.174
| Quoting Removed, click Modern View to see
You are thinking of silica sand, not playsand. Silica sand should not be used without a breathing respirator that is rated for silica dust.
I use silica sand in my cabinet blaster, but it has a shop vacuum attached to it. |
| glennster
09-04-2012 12:32:50
75.57.143.173
| dry screened media, close the bottom valve on the pressure pot, then fill the tank with sand. about 3/4 full. put the lid back on, plug your supply air to the blaster. you will have an air valve on the blaster up near the air line fitting. open the air supply valve fully. you should have a valve on the end of the blasting hose where the nozzle is. with the media valve off, open the nozzle valve fully, then adjust your media supply valve about 1/4 to 1/2 turn, to get a good sand flow. never throttle the valve that is by the nozzle. either full open or full closed. if you do, it will plug up and it wears out the valving in the nozzle. |
| old
09-04-2012 11:02:21
4.245.13.27
| I have one of those. It had 3 valves on it when O got it and yep had the same problem. I removed the valve at the bottom so it now has only the 2 upper ones and as long as the sand is good and dry and the air is good and dry it does ok but you do at times have to shake it some to keep it going |
| Bill in IL
09-04-2012 10:18:59
132.3.49.68
| | The valve at the bottom never gets opened fully. Only till the sand starts to flow. Usually have to mess with it a couple of times Last time I used mine I ran it without the valve at the end of the hose cause I was tired of unplugging the hose. Seemed to work just as well. Someone else mentioned on here to use coarser abrasive in the cheap units cause it flows better. Have not tried that yet. Still think waterblasting off the pressure washer is easier and less messing around. You may not have a pressure washer or want to deal with the water mess. |
| edward will
09-04-2012 10:00:36
24.129.235.11
| Hi If your sand is damp it will plug up and if it is contaminated especially if it's a small unit. Screen some sand then spread some out in the sun to dry then try to see if that makes a difference. Jim Will |
| Mike (WA)
09-04-2012 10:10:53
69.10.199.107
Re: Cheap sand blasters in reply to edward will, 09-04-2012 10:00:36
| You also have to have dry air - air will trap moisture as its being compressed, and unless your setup delivers dry air, you'll plug up in short order. |
