OT: Roof flashing
Slowpoke
I need some new flashing like the one in the photo, but don't know the name. It's probably from the eary '50s. Every thing now is type B for metal. I have Transite Flue Pipe for water heater and furnace and don't want the expense and hassel to change it. Anyone know the name and if the old style flashing is still sold?
Thanks
That was probably not a factory made item but a custom made by a local shop. Most any good heat and air shop should be able to duplicate it. But, the metal will likely be thinner. Unless you spend the big bucks and have one made from copper. That'll last forever, but it ain't cheap.
I will paint and use the 4" one in the photo, but I have a 5" that is in pretty poor shape and would be better off replacing it. They were installed prior to 1970 so they have 40+ years of weather.
Slowpoke, Surely any good Sheet Metal Shop worth their Salt should be able to make one for you. Now you may not like the price but that is not the issue here. The one you have just Aluminum Paint it and away you go! Hope this helps!
Later,
John A.
