Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
Drilling holes in glass tile
awlknottedup
08-31-2012 14:15:47
I need to drill some holes in glass tile. What is the preferred method? Hole size can be anywhere between 3/4 and 1 1/4. What about rough edges?
Richard G.
09-01-2012 17:42:59
 Re: Drilling holes in glass tile in reply to awlknottedup, 08-31-2012 14:15:47
Yesterday my son called and said a huge plate glass window in the store his missionary office is renting had a crack growing up from the bottom. Saw this thread a little later and did some research.
He went to Lowes and picked up a glass bit for a Dremel tool. Followed instructions and drilled a 1/8 hole at the end of the crack. so far so good..
Thanks, Richard
big fred
09-01-2012 15:22:51
Haven't tried in glass, but I use diamond coated hole saws for porcelain tile. Got em at Home DePot. Pricey, at about 10 bucks for the 5/16 diameter, but when you have the tile already set, you really, really, don't wanna break it.
George Marsh
09-01-2012 06:07:46
Go to ebay, buy it now. I purchased a small cheap set of 5 for around $15. Not as nice looking as the ones cannonball posted, but cheaper. If you need an individual diamond hole saw you can get them for around $3-4. I use my drill press and use a few drops of water to keep it cool.
I drill 1/2 inch holes in unusal glass bowls or cookie jars to make flower pots for the Boss. No ruff edges to speak of.
Drilled 1/2 inch holes in glass block to put Christmas lights inside block.
George
cannonball
09-01-2012 03:48:59
old_bc
08-31-2012 21:57:01
This may be your answer.
Russ from MN
08-31-2012 17:28:37
Simmilar tojackbrit, I have glued down a piece of plywood with the same size hole, and then use a carbide hole saw with lots of water. Stop once in a while and use a wet shop vac and suck out the grindings and water. Go slow!
jackbrit
08-31-2012 16:54:57
drill press, copper pipe, grinding compound, clay wall around the area with a coolant? The spinning pipe is the bit and compound abrasive is the cutter.
J_P
08-31-2012 16:47:28
I have drilled quite a few holes in glass block so my wife could make Christmas ornaments. I'd have to go out to the shop and look at the bit but the holes were big enough to stuff a string of Christmas tree lights through. If I remember correctly I got the bits at Menards.
DON TX
08-31-2012 15:45:44
Hardware stores and hobby shops have tile drills with spear tips to drill glass and ceramic tiles but may not be more than 1/4". For the size you want you will have to take to a glass shop or if the edge doesn't need to be nice you can drill a circle of holes to chip the larger hole out. HTH
DON TX
Tom in TN
08-31-2012 14:19:43
awl,
I've never used one, but Home Depot used to sell drill bits specifically for glass tile. If there's a Home Depot near you, you might check with someone in the flooring department.
Good luck,
Tom in TN
Copyright © 1997-2015 Yesterday's Tractor Co.
