Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: Tank Float - Gravity Feed Question
[Return to Forum]
Kerwin
08-16-2012 14:00:06
204.54.36.245
Not sure if this is the right message board, but just wondering if anyone else has set up a stock tank to be gravity fed from a separate collection tank. I'd like to start collecting rain water from at least one barn into a poly tank, then hook it to a tank/float setup.
My biggest question is what float is going to give me flow with a small amount of head pressure. Hudson valves list needing 8 psi minimum. Jobe ROJO valves say they work from 0 psi up. Tank would be in the 500-600 gallon range, but it would be mounted only about 4-5 feet off the ground near watering tank.
[Reply]   [No Email]
oldfarmtractor
08-19-2012 13:37:37
166.249.140.157
Re: Tank Float - Gravity Feed Question in reply to Kerwin, 08-16-2012 14:00:06
I am not sure how much flow would be needed but I think I would use a toilet tank valve. They are cheap, dependable and easy to adjust.
Believe it or not, they use them to keep the level right on the devices that fill wine bottles at the smaller wine makers.
  [Reply]  [No Email]
paul
08-17-2012 13:22:42
66.44.133.112
The cheap floats sold at the farm supply store work for me, I have a cistern with low head pressure. Dad would srill the small float hole out a bit bigger when he had 60 cattle, I just use as is for the 25-30 head. With lower pressure, the hole can be bigger and the float will handle it.
--->PAul
  [Reply]  [No Email]
PJH
08-16-2012 17:02:39
50.40.224.72
My stock tank float has a chunk of styrofoam in it that rises up and closes off a little hole to shut off the flow. Costs about $15 and the last one is at least 10 years old. It's totally controlled by the water level and has nothing to do with pressure.
  [Reply]  [No Email]
Diydave
08-16-2012 16:07:12
96.244.156.194
Hook it up to your stock tank, with a straight valve, and crack the valve to let just a trickle of water out, to fill your stock tank. Adjust, to keep the tank full, but not overflowing. I do this with my herd, about a 1/8" trickle, will keep 6 cows wet, year round, and won't freeze, in all but the coldest weather, here, in MD.
  [Reply]  [No Email]
JMOR
08-16-2012 14:15:56
72.181.173.171
Re: Tank Float - Gravity Feed Question in reply to George Marsh, 08-16-2012 14:00:06
Sounds like you are out of luck with the Hudson at 4 to 5 feet head pressure. For 8PSI, you need about 18 feet.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
