| Tool Talk Discussion Forum |
Topic: stuck pipe
[Return to Forum]
| Author |
[Modern View]
| scottsdad
08-14-2012 09:21:24
209.50.28.144
i have marti9n houses on telescoping pole like top rail well i have two peices that are stuck together dont know how guess rust even tho its galvenised can't drive them apart with a hammer tried to put penetrating oil down between them also tried heat with propane torch and twisting with pipe wrench any suggestions would be appreciated two pieces are about 5' long |
[Reply] [No Email] | |
| Puddles
08-15-2012 17:55:12
24.113.77.208
| Puddles
08-15-2012 09:18:19
24.113.77.208
Re: stuck pipe in reply to Pete black, 08-14-2012 09:21:24
| In the past I've submerged couplings in hot oil, and packed the shaft in dry ice, and pore rubbing alcohol over the dry ice. |
| JOB
08-15-2012 17:45:50
74.36.131.224
Re: stuck pipe in reply to Puddles, 08-15-2012 09:18:19
| This shaft assembly weighted 1800 pounds, I don't know how we could have packed it in dry ice. I guess anything is possible. The coupling weighed enough that two men could not pick it up. To put it back on the shaft we picked it with an overhead crane and hung it level and plumb with the shaft while heating so it would slide on. This shaft is turned by a 1750 horse power electric motor spinning 750 R.P.M.I worked on a smaller shaft some years ago where the shaft may have been five inches in diameter. To remove it we used two #15 tips on two oxygen/ acetylene rigs. One tip could not heat the coupling fast enough and the shaft got hot also. To put the coupling back on it was put it a oven that maintained 375 degrees all day. That coupling had to be carried up two flights of stairs and a couple of hundred feet to be slid on the shaft outside when it was -20 degrees. That one a man could carry, but I don't think oil would have helped. May have hindered a little. |
| JOB
08-15-2012 08:15:03
74.36.129.103
Re: stuck pipe in reply to scottsdad, 08-14-2012 09:21:24
| | When heating a bearing race or the pipe as your problem is. The outside pipe needs to get hot fast, if you heat it slowly the inside pipe will get hot and expand also and nothing will budge. If the larger pipe is open on the end put another smaller pipe in that end and try to drive out the first small pipe. If you have co2 try Puddles method. I recently removed a shrink fit coupling from a 8" shaft. the coupling was heated with two propane weed burners. We did not check temperature on the coupling when we removed it but it was driven off the entire way. when it was put back on the coupling was heated to 350 degrees and went on with a lot of clearance. The inside material needs to be as cold as possible. |
| Puddles
08-14-2012 09:36:01
24.113.77.208
Re: stuck pipe in reply to JRSutton, 08-14-2012 09:21:24
| Try a #12 rose bud on a oxygen acetylene torch, get the outside pipe hot as you can, then shoot a CO2 fire extinguisher inside the other pipe. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
