Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: OT dodge dakota
[Return to Forum]
cb
08-04-2012 15:04:07
96.18.76.191
slightly off topic.. have a 2002 dodge dakota, 6 cyl.. without warning, will not idle.. will start and if you keep gas petal pressed down past the idle it will run. if you let off the gas it will not idle and will stop running. is this a sensor problem. thanks for any help
[Reply]   [No Email]
ASEguy
08-05-2012 17:11:48
68.186.162.134
Re: OT dodge dakota in reply to cb, 08-04-2012 15:04:07
AIS motor could be the problem as Brian stated, but as Ryan stated correct voltage to the AIS motor is necessary for it to operate properly. Have your battery load tested and if it's good clean the AIS pintle and throttle body. If that doesn't correct the problem you may need to replace the AIS motor. The only way to properly clean them is to remove the AIS motor from the throttle body. Clean the throttle body with carb cleaner spray and an old toothbrush until it looks new on the inside. This includes the throttle plate. Hope this helps. Gerard
  [Reply]  [No Email]
Bryan iniowa
08-04-2012 19:15:57
207.191.221.191
Idle control motor is good bet . We replace a lot of them .
  [Reply]  [No Email]
CliffP
08-04-2012 18:08:33
68.95.48.213
I just went through the same thing on a 4.3 v6 . After many months of it running great above idle, but wanting to die if you took your foot off the accelerator, I pulled the distributor cap. Was amazed that the thing would run at all. The top of the distributor had gone to pieces, multiple pieces, laying all around the inside. After installing a new one, I felt like I was driving a new vehicle.Just something to check, only takes a couple of minutes and you may be surprised.
  [Reply]  [No Email]
pete 23
08-04-2012 16:49:42
74.32.238.2
I would guess it is the idle motor giving problems. I have a 98 that gives me grief. It does not drop a code to steer me any place in particular. Of course the idle motor is interconnected with a couple other sensors like the throttle position sensor for one. I ran a jury rigged idle motor for some time so the plunger could not move and I adjusted the idle speed with washers under plunger. Right now I have the new unit on there and it has been working ok but I would not bet it will continue. That brings me to another happening. With all that talk about Toyota's running away a few years ago. Well, one day, I drove out to the shop where I was working on a customer's tractor. Jumped out of truck, went in to open shop door, stood in there a few seconds talking to owner, engine takes off like a screaming demon, I ran to truck but it shut down t normal before I got there. It never happened again but it made a believer out of me that these things can happen. Of course, I believe I could have shut this one down with the key if need be.
  [Reply]  [No Email]
Ryan - WI
08-04-2012 16:12:43
66.114.188.64
Re: OT dodge dakota in reply to MartyInVa, 08-04-2012 15:04:07
Check your battery connections and have the battery tested. Dakotas (I have a 99) will not idle if the battery is bad. The way it was explained to me is that there is no connection directly from the alternator to the coil, it must go through the battery. If the battery is low there isn't enough voltage to send power to the coil.
  [Reply]  [No Email]
cb
08-04-2012 17:17:47
96.18.76.191
Re: OT dodge dakota in reply to Ryan - WI, 08-04-2012 16:12:43
thanks for the replies. i will check my voltage on battery, but it will crank the engine.it just will not idle, if i can keep it running say 20 minutes or so sometimes it will drop back and will idle. but not every time.. have a nice day
  [Reply]  [No Email]
cb
08-04-2012 17:16:59
96.18.76.191
thanks for the replies. i will check my voltage on battery, but it will crank the engine.it just will not idle, if i can keep it running say 20 minutes or so sometimes it will drop back and will idle. but every time.. have a nice day
  [Reply]  [No Email]
wvajim
08-04-2012 19:19:05
173.80.239.165
Re: OT dodge dakota in reply to cb, 08-04-2012 17:16:59
Idle air control valve is sticking.
  [Reply]  [No Email]
cb
08-05-2012 05:04:13
96.18.76.191
Re: OT dodge dakota in reply to wvajim, 08-04-2012 19:19:05
thanks again, it seems the consenses is that the idle sensor/ control valve is the problem.. a friend is coming monday, he has one of those code checker deals.. i'll tell him of your suggestions have a good day
  [Reply]  [No Email]
cb
08-05-2012 16:54:32
96.18.76.191
Re: OT dodge dakota in reply to cb, 08-05-2012 05:04:13
thanks for the suggested areas to check..and the the results i should get.. i'm hoping to have the problem fixed soon
  [Reply]  [No Email]
C.R.
08-05-2012 08:37:33
72.251.63.46
you ought to be able to read some of your codes turn the key from the off position to the on position without cranking the engin over three times then watch your check engine light it will blink out your codes you have to turn the key sort of slowly a second or so ,but not too slow, might have to do it a few times to make it work.Have a pen and paper to write the numbers dowm, you can look up the codes at several sghts a good one is allpar is a god one when it flashes a five - five your done with the codes good luck
  [Reply]  [No Email]
scotc
08-05-2012 14:31:22
75.245.228.154
Re: OT dodge dakota in reply to C.R., 08-05-2012 08:37:33
It's an 02 it will have a digital odometer and give a 5-digit code starting with a letter and then 4 numbers.
Don't try to adjust your timing by turning the distributor either, on a magnum engine. The timing is set by the computer reading the crank sensor.
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
