| Tool Talk Discussion Forum |
Topic: Regearing a '84 chevy c70?
[Return to Forum]
| Author |
[Modern View]
| Mikefromcny
07-17-2012 18:57:10
74.78.198.207
Just curious if anyone has a changed the rear axle gears (2spd) in an old c50-c60-c70?I have an 84 C70, 366 gas, 5 speed, 2 speed rear. Unsure of rear axle ratios, but it seems like I can afford to go higher, I can start in 2nd high empty. It has a 20ft rollback bed on it. Its just used occasionally to move tractors, but it when is the speed limit is 65 on the highway, the 366 is turning 3300rpm at 55. 22.5 tires on the truck. Not sure where I can buy a different ring and pinion or how difficult it is to change, seems like there would be some good used rear ends kicking around from people scrapping the rest of the truck. Any Ideas are welcome. Thanks guys. |
| d beatty
07-20-2012 20:08:51
24.12.128.253
Re: Regearing a '84 chevy c70? in reply to Mikefromcny, 07-17-2012 18:57:10
| The freight line that I worked for had three Chevy box trucks set up with a 366 with a 5-2 behind it and would do 70 mph with a pay load of about 12,500 lbs. We also had about ten semi tractors set up the same way.They were running ten hundred twenty's for tires back in the late 70's through the 80's. |
| big a
07-18-2012 21:09:03
98.19.46.230
| Just a thought, but would the 3rd member out of a GM school bus possibly contain higher gears?
Might be cheaper and easier than swapping ring and pinion when all is said and done. |
| hd6gtom
07-18-2012 16:07:11
75.170.237.148
| Mike If the 4 bbl carb is set right you will have plenty of power with the 366 to go to taller gears. I owned several of them, bought new in the 70's. They would all run 75 mph with loads on them. One had a low 1 gear, clark tranny but would top out at 80+ mph with no trouble. Keep in mind, hauling tractors or farm machinery is a hard pull no matter what setup you have. |
| onefarmer
07-18-2012 12:01:25
66.87.2.92
| Maybe a Ranger overdrive would work for you. It would install ahead of the trans, so no need to change the speedo gears and no need to open the rearend. |
| The tractor vet
07-18-2012 08:07:20
76.212.234.198
| Look for a truck salvage yard and start looking around . Ya ya can swap out the pig for a higher gear ratio but the comes the problem of the speedometer gear changes not only in the transmission but the two speed thing as what they call that escapes me at this moment. The next down side is that when ya make the gear swap with a gasser is the loss of pulling power as them old gas truck engines were no power house . Might be a lot less of a hassle to go find a older diesel box truck that has more road friendly gears and remove the box shorten up the frame to your needed length and move your bed over on to the new diesel.Over here finding a diesel box truck is not hard and making it into what you want requires a little work to shorten them up by unbolting the rear axle and moving it ahead to what ever wheel base you need and redrill some holes and shorten up the drive shaft. |
| timcasbolt
07-18-2012 05:36:15
72.23.207.250
| | Never done one in a big truck, but have done lots in cars and pickups. The parts are very heavy, but the work isn't complicated. You can get step by step instructions on the internet. I doubt you'd consider it time well spent though. |
| danofarming
07-17-2012 19:00:18
69.8.164.11
| You could put 11 R 24.5 rubber on it that would boost your speed bout 5 mph. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
