| Tool Talk Discussion Forum |
Topic: Welding questions
[Return to Forum]
| Author |
[Modern View]
| charlie M
06-20-2012 17:54:01
74.34.216.81
Looking for a little advice on a small welding job. I'm very much an amateur welder. I have the wheel off of the rear of the older New Idea hay rakes that I want to try welding. It is a 2 piece wheel so it come apart in halves. Its solid metal and will clean up. It has a split on one side where the rim meets the flat metal plate that bolt the 2 halves together, about 4 inches long.I'm looking for a suggestion on type of rod (I'm assuming a general purpose rod will work) and a starting point for amp setting. I have a Lincoln stick welder.I seem to always have a problem with burning a hole when trying to get started.Any pointers would be helpful. |
| soundguy
06-21-2012 18:10:30
173.104.17.41
Re: Welding questions in reply to charlie M, 06-20-2012 17:54:01
| | tire off. clean out crack.. v cut and drill stop it. if ac.. go 6011 1/8 on about 90a. 6013 is not a bad rod.. just low penetration. if the 6011 makes it ugly.. grind.. or topcoat with 6013 and then grind.. your call. btdt.. easy fix for you to learn with. tip.. bolt the rim to a piece of flat stock to keep it from warpin.. ( shouldn't on a small weld.. ) |
| Billy NY
06-21-2012 06:47:43
67.248.100.3
| Here is a link to the video that shows what happens when you weld a rim with a tire mounted on it, same thing can happen even if the bead is broke, tire loosely on rim. Absolutely remove and separate tire and rim when welding. |
| Dusty MI
06-22-2012 04:35:02
108.88.167.219
Re: Welding questions in reply to Billy NY, 06-21-2012 06:47:43
| Quoting Removed, click Modern View to see
EVERYONE should watch this safety video.
Thanks Billy for posting it.
Dusty |
| Stick welding
06-20-2012 22:13:00
96.53.210.246
| | Make sure the tire is off the rim. I'm guessing you just have an AC welder. 6013 aren't a very good rod. A better choice would 7014 for a wheel like you have or 7018 if your welder will burn it. 7014 is an easy rod to use and hold an arc. 1/8" or 3/32" (if you're worried about burning through) would work. Clean it up good with a grinder or file but practice your welding on some scrap first. Weld from the end of the crack towards the good part of the wheel so you don't leave the crater at the end or burn a hole. Actually welding from both ends towards the center of the crack is the best way as it doesn't leave a crater for a crack to start. Let it cool by itself and then weld the other side. You can grind the weld flat where it bolts to the plate if you need to. A 1/8" rod should be about 120 to 135 amps and a 3/32" around 90 to 105. If you don't feel confident enough to do the repair, it wouldn't be very expensive to have a shop weld it for you. |
| DiyDave
06-20-2012 19:14:32
96.244.156.97
| Vee out the crack, and drill a hole, at each end, if possible. Buy yourself a box of 6013 rod (it's forgiving, and easy to use, less slag adherence)1/8-3/16" diameter. As to the initial setting, try around 90-100 AMP, and remember that the sound of a good weld is like bacon fryin. |
| dandeere
06-20-2012 18:25:56
75.73.138.108
| Hey Charlie, PLEASE TAKE THAT TIRE OFF RIM before welding. Google tire welding explosion! I'd try 1/8" 7018 at about 120 amps. Dan |
| charlie M
06-21-2012 18:50:09
74.34.216.81
Re: Welding questions in reply to dandeere, 06-20-2012 18:25:56
| I wouldn't even had considered trying to weld the rim with the tire on it as for no other reason I would have expected the tire to melt or catch fire. Tire has a tube also. Thanks to everybody for the advice. I'm going to give it a shot this weekend. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
