| Author |
[Modern View]
| lloyd in sc
06-04-2012 15:16:42
24.148.185.169
Driving over to a friends house & saw a stihl 025 (now a 250) out with the trash.Picked it up & cleaned it off, put in a new plug. new gas & it fired up runs good & has decent compression. The oil isn't feeding into the bar. What to check first? |
| Bob - MI
06-07-2012 13:58:59
75.129.96.71
Re: stihl 025 bar oiler dry in reply to lloyd in sc, 06-04-2012 15:16:42
| | I will send you a trail cam and we can watch to see what this guy puts out next. Maybe I should send you a list of what I am looking for. It's kind of long however..... |
| Ozlander
06-07-2012 08:18:59
76.210.38.135
Re: stihl 025 bar oiler dry in reply to cj3b_jeep, 06-04-2012 15:16:42
| There's a filter on the end of the hose in the oil tank. Pull it out with a wire hook and clean it. |
| Rollie NE PA
06-06-2012 19:22:57
71.173.36.203
| [quote="lloyd in sc"](reply to post at 23:16:42 06/04/12) [/quote Turn the saw upside down. There should be a screw that adjust the amount of oil going to the bar. Turn the srew to full open. I may be wrong. The 025 may not have a oil flow adjustment, but it won't hurt to check.
This post was edited by Rollie NE PA at 19:28:05 06/06/12. |
| d beatty
06-06-2012 20:04:46
24.12.128.253
Re: stihl 025 bar oiler dry in reply to Rollie NE PA, 06-06-2012 19:22:57
| Rollie there is no oil adjustment on the 025. My MS 250 when new would turn the bar blue with steady sawing ( bar not getting enough oil). Took it back to dealer and they put a new high out put oil pump for a 025 on it. The 025 had a standard oil pump and you could get a high out put pump. Some dealers will not put a high out put on a MS 250 because of EPA rules and regs. |
| Butch(OH)
06-07-2012 08:42:34
70.62.13.146
Re: stihl 025 bar oiler dry in reply to d beatty, 06-06-2012 20:04:46
| The standard oil pump can easily be modified to give same flow as the hi volume unit and is not hard to do. SHould not be hard to find a how-to by googling the subject. |
| d beatty
06-07-2012 20:36:17
24.12.128.253
Re: stihl 025 bar oiler dry in reply to Butch(OH), 06-07-2012 08:42:34
| The MS 250 was a new saw and under warranty. Any modification would void warranty on new saw. The new high out put oiler would not void the warranty. |
| JOB
06-04-2012 18:31:30
74.36.128.102
| I had an oiler put in my stihl and it stopped working. I said it should have lasted longer than that. I poured a cup or so of gas in the oiler and shook it around then dumped the gas out. Did it a second time then put in bar oil and haven't had a problem since. Worked for me will it work again????? |
| lloyd in sc
06-04-2012 15:51:56
24.148.185.169
| Thanks, all, just needed a place to start. |
| d beatty
06-04-2012 15:38:36
24.12.128.253
| The first thing take bar off and see if all oil holes are open. Also take oil cap off and see how clean oil tank is . I know guys that never clean around cap before opening it and let dirt and crud in it and plug up oil intake. It could also have a bad oil pump. If you would have to replace the pump get the high out put for an 025. I bought a MS250 two years ago and it didn't put out enough oil and bar turned blue. Dealer put a new 025 high out put pump on it and I don't have problem with bar turning blue. |
| molinebob
06-04-2012 15:29:16
69.89.198.181
| Id be checking the oil pump drive gear, behind the clutch cover on it, just a little plastic gear that gets worn very easy, if not that the hose inside the oil tank may have came off, or developed a hole..Bob |
