I'm still using a few pole barns I built 40 years ago. No rot - but to be fair - the wood I used back then was either creosote or CCA treated. You're not likely to find poles with that treatment now since they are now allowed in exposed-residential work. ACQ is more the norm.
You have to be very careful to get poles with the correct long-term below grade treatment. Many do not. I like pole construction because I always work by myself. No helpers. I built all of these alone -with help from my backhoe.
Here's an addition I built on a house 20 years ago. 6"X6" poles for the first floor and 2" x 6" frame construction on top of the poles for the 2nd floor. It was a tough job since I saved the old dug well that had been in the "back yard" and is now in the house-kitchen. No concrete pads under these poles because I hit hard shale 4 feet below grade.
The laid-up stone well has the blue tarp over it.
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=well_beginning.jpg" target="_blank">
</a>
Framing the floor around the well . .
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=well_outside.jpg" target="_blank">
</a>
From a distance . . .
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=houseupper2.jpg" target="_blank">
</a>
Getting the walls on . .
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=house_mid2.jpg" target="_blank">
</a>
Close to done . . .
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=house_almostfinished.jpg" target="_blank">
</a>
Well inside the house - in what became a big kitchen, along with a Rumford wood-cooking fireplace and bake-oven.
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=new_kitchen1.jpg" target="_blank">
</a>
Here's a pole barn with two purposes. One roof with a special angle to hold solar panels and the rest to hold farm and construction equipment. These 6" X 6" poles are on 2' diameter concrete pads.
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=solarbarn1.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=solarbarn2.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=solarbarn25.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=solarbarn3.jpg" target="_blank">
</a>
This is a four-story barn I built 30 years ago. No rot anywhere. 6" X 6" directly in the ground. Some with concrete pads and some with not if hard-pan was hit. Pole construction first level, and 2" x 6" frame above. Three full floors and fourth just a small bedroom.
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_1886.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_1881.jpg" target="_blank">
</a>
Here's the one problem - I built in the trees and tried to save all I could. This ash "sapling" has grown right into the roof and I'll have to climb it and cut it down soon.
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=100_1882.jpg" target="_blank">
</a>
Here's a two story pole barn I just finished in the NY Adirondacks. 6" X 6" poles on first story and 2" x 6" frame on second. Roof is all 2" x 10" rafters (no trusses). Built it right over an old camper trailer so we had a place to say while working there.
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=Indianlake1.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=Indianlake2.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=Indianlake3.jpg" target="_blank">
</a>
<a href="http://s104.photobucket.com/albums/m162/jdemaris/?action=view&current=Indianlake4.jpg" target="_blank">
</a>
