I have a 4 stroke gas powered EZ-GO Golf Cart that is running poorly. When the motor is cool, it runs and is driveable, but still does not seem like the rpm is as high as it used to be nor does it seem like it is as powerful. If I drive it continually (like going to check on the hay field)it seems like it gets weaker and weaker as the motor warms up, to the point that it will barely move. Then, if I stop and try to start again, the motor just turns over and chugs...but then is driveable again when the motor cools off somewhat.
I pulled the plugs and they are dry, but there is a lot of black carbon on them. Thought maybe I had a weak spark so I swapped coils with another running cart that I have, but this did not fix the problem.
I haven"t had time to troubleshoot any more. Anyone have suggestions on what could be causing this problem. I really need to get this fixed as I use this cart ALL the time!
Thanks,
Tim
Thanks,
Tim
