Anonymous-0
Many of you may remember my posting this problem a couple weeks ago. I followed up on many of the suggestions you kind folks made.
Throttle body equipped engine stalls unpedictably while vehicle is at an idle. This can happen while it is in gear, in neutral, or shifting forward to reverse, (automatic transmission). Truck runs perfectly down the road and has good power.
Previous owner had MANY parts installed, (throttle position sensor, coolant sensor, EGR valve, pick-up coil and distributer, fuel pump and sending unit, knock sensor etc.) to try and correct the problem, but no luck.
The truck starts/re-starts perfectly.
Today, while the truck was idling I jiggled the wires to the pick-up coil, throttle position sensor, coolant sensor, etc. but was unable to cause a stall.
I plugged off the vaccum to the EGR--no difference.
Fuel filter is new. Last summer fuel pressure tested normal at various rpms while running in the shop, (truck has sat in garage since last October).
I did notice a lean smell when it stalled while I fiddled with in the shop today.
I could ramble on, but will respond to all suggestions/questions you kind folks make.
I'm not too techy, but this thing has me baffled.
Thank you,
Glenn FitzGerald
Thank you,
Glenn FitzGerald
