TractorLinks.com
Tool Talk Discussion Forum
how to drill square holes in steel
Joe W.
03-24-2011 17:20:37
I want to make 1/4" square holes in 1/8" x 1-1/4" plate steel. I'm going to insert 1/4" carriage bolts in them. I found a tool online called a rotary broach which does that but it is way beyond my skill and economic level. I believe the broach is over $100 plus the cost of a special tool to hold it. If I had one hole to make I suppose I could drill it and use a file to finish it which would take forever but I need to make 12 holes. Anyone have experience making square holes in 1/8" flat steel? Or should I just use machine bolts in round holes?
Mike in AR
03-27-2011 15:36:31
 Re: how to drill square holes in steel in reply to Joe W., 03-24-2011 17:20:37
I have some parts I regularly produce in my shop requiring a 1/4" square hole through 3/16" thick steel.
I bought a 1/4" High Speed Steel Cobalt tool bit ($3) and ground a round pilot on one end .245 diameter to go through a .246 hole. Use a 'D' drill bit.
From the round pilot slowly taper the tool bit up to full square and grind teeth into it like a broach. I use a Dremel moto tool with the little cutoff wheel to do this.
It pushes easily through the hole with a 2 ton arbor press and took me about 15 minutes to make.
The hole is dimensionally perfect. This aint theory folks, I really do it.
JDseller
03-26-2011 23:42:10
I have several square files that are the size for 1/4,5/16,3/8 carriage bolts. I just drill a round hole then I put the file in my drill press (not running LOL) and just use it to push the file through the sheet metal. It works real well on thinner steel. It is fast too. The square file works just like a broach would.
Fred Martin
03-26-2011 05:45:55
Drill the 1/4 hole, grind an old punch or chisel to the size square you need with a bit of round lead on it to get it started in the hole and drive it through and grind the slobbers off the back side. ohfred
Johnny form MI
03-25-2011 17:53:34
Just buy a square drill! and keep it sharp.
El Toro
03-25-2011 16:50:41
Check with your local metal shop. They have hydraulic punches that can punch a 13/16" hole in 3/4" steel. They may have square punches too. Hal
farmer boy
03-25-2011 16:09:28
I would have to agree with every one who suggested going to a shop with an iron worker. Would take 10 minutes to do it and it would be a perfect hole. Call first and see if they have that specific punch though.
Dave Sherburne NY
03-25-2011 15:10:49
How about ROUND HEAD RIBBED NECK bolts you may have to drill the holes just a little bigger
Dusty MI
03-26-2011 15:48:50
 Re: how to drill square holes in steel in reply to Dave Sherburne NY, 03-25-2011 15:10:49
I've used this type of bolt, they worked nice and they have a small head.
I got them some other place than McMaster.
Dusty
Mike M
03-25-2011 13:23:03
Why carriage bolts ?
I'd use regular bolts on steel. If you couldn't get to the back with a wrench or they needed held in some way tack weld them on.
Cliff(VA)
03-25-2011 05:57:49
I read a book on blacksmithing where the author had gotten a cherry job in the military by betting his sargent he could "drill a square hole". He made a tapered triangular bit, drilled and filed a square hole in a guide plate, attached the guide plate to the work, and allowed the work and guideplate to float while he drilled slowly on a drill press. He got the job.
That being said, quit being a wimp 8^) and get a couple of new (sharp!) quality files and get to filing. It won't take long once you get going. I would buy a couple of Nicholson 4" or 6" ba$tard cut square files with handles and get to it.
Keep your files separated and not loose in your toolbox. They will last a lot longer that way.
Cliff(VA)
And yes I am a file-aholic
NCWayne
03-24-2011 20:30:54
A 'rotary (rota) broach' us nothing but a form of hole saw,more appropriately called an annular cutter. What your actually needing is a square, push broach. With it you drill a round hole of the appropriate size and then push the broach through. Each step on the broach takes off little metal taking the hole from round to square. They are a bit pricey but they work great. I've used them many times making holders for our line boring setup that accept square shanked carbide tooling. Some of those holes were in 1 1/8 diameter rods and soime in even thicker material so 1/4 plate should be no problem. Just depends on wether you have a press to push the broach through of if you want to spend the money to buy one.
farmboyWI
03-25-2011 14:28:11
 Re: how to drill square holes in steel in reply to NCWayne, 03-24-2011 20:30:54
The square push broach looks interesting, what type of press do you need? Are you talking hydraulic shop press, or somthing made for that tool or that type of work? Any fixtures or jigs needed?
NCWayne
03-25-2011 19:23:02
 Re: how to drill square holes in steel in reply to farmboyWI, 03-25-2011 14:28:11
For the square broaches like this any press that will handle the force necessary to push it through would do. Obviously the thicker the piece the more power needed to push it through as more teeth would be engaged and cutting the material. Honestly I don't know how much force it takes to push one through the various thickness metals but I always used our 75 ton, homeade press and never had any problems. Beyond the force needed to push it through the only other requirement is a press with enough throat to accept the height of the broach and material between the bed and the ram, and then the same amount of room on the backside for the broach to push through into.
Paul from MI
03-24-2011 20:10:35
Drill them round, file square with a square file. On 1/8 thick stock, probably about a 15 minute job. Lots of time we spend more time trying to think of an easy way to do something with a machine when it would be faster to do it by hand.
If you just want to use carriage bolts it's not a high precision job.
Jiles
03-24-2011 20:06:18
I don't know if this will work in your situation but I have made many small square holes by drilling the propersize hole and driving a "cut masonry nail
" to the desired size hole. It works good for thinner metal and might work for thick--if heat is used.
These are small rectangle/tapered nails. Do a Google search for an image.
Russ from MN
03-24-2011 19:57:56
I could drill the holes and file them square in less time than it takes you to read all these posts!
bison
03-25-2011 08:45:48
 Re: how to drill square holes in steel in reply to Russ from MN, 03-24-2011 19:57:56
X2
old
03-24-2011 19:52:15
Sorry you do not drill a square hole you have to have a punch press to do so and you do not want to pay for one. That said your a lot of times money ahead to have a machine shop punch the holes for you. Other wise a you drill your hole then use a file etc to square the hole out
IOWA NORTHEAST
03-24-2011 19:41:59
If you do not find these other option to your liking try this. Drill your hole, heat around the hole and insert the carrage bolt and smack it with a hammer, then grind the uneven surface if needed.
You can make your own punch from square stock, and grind a point on it.
j heitkempr
03-24-2011 20:01:58
 Re: how to drill square holes in steel in reply to IOWA NORTHEAST, 03-24-2011 19:41:59
Your Idea Might Work on thefarm,But Old knows the right way its done ina factory,, forget dremels
Louis Torrans
03-24-2011 19:39:42
I think all you need is a Dremel Tool. Use it like a die grinder.
DnA
03-24-2011 18:55:28
Was visiting an ornamental iron fab shop a year or so back, small one man operation, and he had a punch machine to make square holes in thin square tube. If you have one nearby maybe.....
RodInNS
03-24-2011 18:46:22
Find a shop with an iron worker and have them punch the holes. For one or two you could drill/file them but I think it'd get old after 12 holes. Could be done tho....
Rod
Jiles
03-24-2011 18:43:19
 Re: how to drill square holes in steel in reply to soundguy, 03-24-2011 17:20:37
What is a "wasplip punch" :?: :?: :?:
Tom-TX
03-24-2011 18:36:01
The shop where I buy most of my steel for projects has a punching machine that will do them in about the blink of an eye. Check around. Tom
cubcorn
03-24-2011 18:22:07
Just drill your hole, heat around it and smack a wasplip punch thru the hole
soundguy
03-24-2011 18:20:30
round drill plus square, flat or triangle file always works for me!
soundguy
big jt
03-24-2011 18:15:54
The square or triangle file is the budget option here.
I know when I put a Ag Leader yield moniter in my combine the kit came with any special tools needed. One of them was a square file for just this sort of situation.
Not sure where you go to get a square file but the triangle ones are available.
jt
soundguy
03-24-2011 20:47:23
 Re: how to drill square holes in steel in reply to big jt, 03-24-2011 18:15:54
i find square files in the same isle as I find needle, triangular, flat and half rounds as well as full rounds. must have 2-3 of each in different sizes out in my shop.
soundguy
JDB
03-24-2011 18:10:32
Take it to a machine shop and have them punch the holes
Slowpoke
03-24-2011 18:01:09
If the thickness of the material is only 1/8", buy a 1/4" tapered square file and do it. It will probably take less than 5 minutes each with trial and error to fit the bolt. Total 1 hour.
RayP(MI)
03-24-2011 17:23:56
Can you make your holes a little oversized, and file out the corners only?
