Butch(OH)
Years ago I purchased a Phase o Matic static converter to run a mill. Worked well enough but hung it on the wall when I upgraded to a true rotory. Now I have purcased a used 3 phase DoAll drill press for shop 2. The Duall is a two speed motor and reversing thus has mounted switches for doing alll this. My question is when I have used these converters before we had them wired hard to the motor and switched the power on and off prior to the converter. The DuAll does not allow this because of the two speed and reversing switches. I would have to power up the converter, then start the motor, will that work? Simple wiring diagram included (hopefully)
