Yesterday's Tractor Co. Restoration Quality Tractor Parts
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Tool Talk Discussion Forum
Topic: o/t how do you put black stove pipe together
[Return to Forum]
wsmm
01-11-2011 15:30:53
72.251.53.229
Looking at getting some black pipe for a barrel stove for my pole barn. What"s the secret for getting it to go together. It"s in a flat piece, that needs to be formed into a cylinder and I haven"t been able to figure out the trick to put the seam together.
Thanks
Bill
[Reply]   [No Email]
GeneMO
01-12-2011 08:38:22
76.4.166.249
 Re: o/t how do you put black stove pipe together in reply to wsmm, 01-11-2011 15:30:53
I put of about 25' of used grain leg at my shop in 1977. It's still there.
Although I used the kinda pipe you are talking about in my hunting cabin as sort of "temporary"
That was in 1996 and I had to replace it last month.
Gene
[Reply]  [No Email]
rustyfarmall
01-12-2011 06:21:34
209.152.78.140
 Re: o/t how do you put black stove pipe together in reply to Bob, 01-11-2011 15:30:53
Used auger tubing is most likely worn pretty thin in several places. That's why it was no longer useable for the auger. I wouldn't want to trust it as stove pipe.
[Reply]  [No Email]
Banditfarmer
01-13-2011 06:59:17
174.103.158.110
 Re: o/t how do you put black stove pipe together in reply to rustyfarmall, 01-12-2011 06:21:34
The tube I got was from a new auger that was bent in transport by a chain binder. Dealer sold it to me for $3 a foot. Its a lot better than any stove pipe made and I feal safer with it than 24 gauge stove pipe being sold now. Bandit
[Reply]  [No Email]
DiyDave
01-12-2011 05:12:38
71.248.25.243
I agree on what others have said, I put 1/4" sidewall 6" steel pipe to run chimney over to wall, through floor, and from there, I use the heavy variety of the black stove pipe, when I can get it. 2 things that help: You need to compress the pipe, from a round cross section, almost to a heart like cross section, with the v of the heart, at the seam. Take the pipe, put it between your legs, while kneeling, and put your thumbs next to each side of the seam, near the center of the pipe section. Press with your thumbs, straight down, when you get it just right, it clicks right in. 30 inch sections are easier to work with than the 60's. The second thing that helps is to get one of cheap sheet metal crimping pliers, and recrimp any tight male pipe ends, makes the assembly easier. I also put 3 sheet metal screws into each joint, near the stove, where most expansion takes place.
[Reply]  [No Email]
Heyseed
01-11-2011 19:51:35
24.127.2.5
Thurlo is right, overbend it and it will snap together. I have used 24 gauge for years and check and clean it twice a season, looking for rust or weakness. Still very solid.
[Reply]  [No Email]
old
01-11-2011 19:38:08
4.245.8.102
I gave up on that cheap last you a year if your lucky pipe and switch to 6 inch well casing and have never looked back. My stove has had the same pipe on it now for over 15 years and it is still holding up real well. I did get lucky when I got that pipe and got it for scrap price in 3 foot piece from a place I worked at
[Reply]  [No Email]
60 acre hillside
01-11-2011 18:09:02
67.142.170.20
Bo is exactly right plus after one is started to go together you slap each side with your hands and it ges together. if it takes long you are doing it wrong. be careul because you can cut your hands. Larger pipe is easier and thinner pipe is easier. hardest I ever did was 24 ga 6" pipe. Did an apprenticeship in a sheetmetal shop. Never got my card
[Reply]  [No Email]
Bob
01-11-2011 18:06:23
64.255.159.192
Leather gloves are a BIG help!
[Reply]  [No Email]
wgtm
01-11-2011 17:56:55
66.11.102.200
You get what you pay for. Quit buying junk and buy some quality pipe.
[Reply]  [No Email]
Banditfarmer
01-11-2011 17:36:06
174.103.158.110
I would like to give you some advice about that stove pipe. It is cheep stuff and will rust out fast then it gets heated up and hot. I have switched over to a 6 inch tube from an unloading auger, Its a lot heaver and is made from better steel and is a whole lot cheeper to buy. Cost me $3 a foot for used 6 inch tube from a guy that sells new augers and repairs them too. Just my two cents. Bandit
[Reply]  [No Email]
PJH
01-11-2011 17:19:31
72.69.93.223
Bill, after you get it snapped into a cylinder like the other posters say - when you put the joints together, the female end goes up so any juice will stay on the inside of the pipe and not run out the joints on the floor.
Paul
[Reply]  [No Email]
MarkB_MI
01-11-2011 16:26:40
166.217.64.51
I just finished messing around with stove pipe. Aggravating stuff. If it doesn't want to lock, you may need to pry up one of the edges so it can catch the other side.
[Reply]  [No Email]
Mt.Man
01-11-2011 15:42:15
74.47.113.181
If you will bend the two long sides together you should be able to see how they hook together. They will interlock. I had a barrel stove in my garage and loved it until the insurance company made me take it out or lose my insurance with them.
[Reply]  [No Email]
thurlow
01-11-2011 15:41:02
74.177.51.33
It's been a while, but IIRC, you've got to bend it past round......to a somewhat 'heart' shape, with the seam at the 'inside' point of the heart.
[Reply]  [No Email]
bo
01-11-2011 15:40:07
12.75.107.236
If it's like duct pipe...you sorta cave it in a bit and stick one part of the flange in and it just snaps together....you have to get a fair amount of angle on the inserted piece.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
