Anonymous-0
Went by a guys shop I know with another friends outer muffler off his dirt bike, to get it welded. There were several aluminum fuel tanks in the shop getting repaired and new straps getting wrapped around where the tanks are mounted. He makes it look easy. His main welding machine is a Miller Dynasty 300. I thought it was only a 200. He runs it off a 30 amp breaker and can't believe how little power a 300 amp TIG machine uses. It uses less power than his Lincoln Square Wave 175 budget machine.
He does a lot of aluminum motorcycle and sled radiators. I know they are one of the trickiest things to repair. He said the vertical tubes are about the thickness of pop cans and with the Dynasty, he can form a puddle and do almost what ever he wants with it. He said it takes around 20 amps to weld them after he bends the cooling fins out of the way. What was rather neat was that he used all of his welding rods. When the rod got too short to hold, he'd leave it stuck to the weld, tack the next rod onto it with the TIG torch and then resume welding. Most guys would just throw the 2 or 3 inch stub away and get a new rod. Diesel fuel tanks are just rinsed with water but if he does gasoline tanks, he has them steamed out. He mostly just uses a wire brush in a drill or a belt sander to clean the aluminum for welding. Thought some people would be interested to know how an experienced welder does aluminum. Strangely enough, he doesn't have a welding ticket, but says TIG welding just seemed natural to him. He does some pretty impressive work that most welders can't do. He was quite busy earlier in the year building solid stainless steel replica hockey sticks for NHL teams to give as awards and retirement gifts. They are identical to the real stick but pretty heavy. He said goalie sticks are about 20 pounds. Dave
