I've had problems with my various grease guns (one Lincoln electric included) in hot weather. Happens in cold too, but very aggravating when it's hot. If you don't use the gun on a regular basis the grease will seep around the plunger and begin filling the rear of the gun, know what I mean? When the gun becomes empty and you pull the plunger back you get a varying sized glob of grease coming out the plunger hole. Maybe this has been a topic on here before, but if it has I've missed it. Anyway, what I have done to prevent this is to clamp a small vise grips on to the plunger rod after having pulled it out to where it stops against the plunger. This prevents the spring from applying pressure on the plunger and keeps the grease where it belongs. Anyone else do this or have a different or better idea? It's been in the 90°s here for the last couple of weeks and haven't had any problems with the guns.
