Rob Hartman
I need some help. I have a 2000 Dodge Grand Caravan w/ 3.8 engine. I have replaced: coil pack, plugs, wires, crank sensor, cam sensor, fuel pump, fuel filter, and air filter. When you go to start it up it pop,pop,pops then starts. It stumbles and coughs when you go to pass or get after it. It gets really bad gas milage if you don't run premium fuel in it. I've sprayed carb cleaner around the intake with no results, I check the timing chain be taking the front valve cover off and turning the engine back and forth, doesn't seem to be any slack. I did notice there was some oil on the cam sensor but I think there is sappose to be. I've also taken off the cat. converter and put new manifolds on it. The check engine light is on and the only code it throws is crank or cam sensor interminent siginal. Any suggestions?? Help would really be appreciated as I have put $1200 in this van and I haven't got it to run right yet. Thank you in advance.
