Anonymous-0
I have another question about the SA200 but it could apply to other equipment. Is the small tube in the rad, under the rad cap a normal type of overflow? I changed the coolant and fixed a tiny leak and after running the machine to check, coolant came out this short tube that goes to the engine side of the rad, after shutting the engine off. I'm thinking the rad will kind of just set it's own level but don't know how it builds up any pressure with this short(3") tube from the inside to the outside of the rad. Didn't the old engines use much pressure? Just curious if this is common? Dave
