Hey Yall!!
I recentally bought a totaled S10 to fix up and joyride around the farm in...
It hit a santa fe going about 55, and so the front of the frame is messed up six ways from sunday. Accually, everything in front of the water pump was destroyed. The sheet metal was so bad i had to burn it off in peices.
So, needless to say, i need a new frame.
Thing is, i dont know how to get one home.
Ive got an old minivan, but im pretty sure it wont fit in there. So, my thoughts are, find a used frame somewheres, take a sazall, and cut it into about six peices, so it will fit. Then, get it home, and weld it back together.
I know welding frames is frowned upon, but its just an old wreck of a farm truck. Its days on any road are over, and it probabally wont go over 30 miles an hour again.
My thoughts are:
Buy frame, cut into peices
Stuff into minivan
Drag home
Grind the edges clean, bevel with angle grinder, clamp in place, weld both sides, then grind down and weld steel brace over other weld.
What kind of rod would be best for this?? How many amps, with AC buzzboz??
Anything else i should know?? Thanks guys
My thoughts are:
Stuff into minivan
Drag home
