Anonymous-0
I called about the SA 200 I dropped off. I told them to call me if it was going to be much over $500. They said $796. Should I be a little upset?
It needed a new carb, spark plugs and magneto parts because the mag seal was leaking and not the front engine seal.
The good news is that the generator was load tested and put out 310 amps at 23? volts which is within specs. So the bottom line is I get an early 60's red face in good running condition for $1400. Should I not worry that they didn't call me or did I get a pretty good deal over all? All I need now is a battery and cables along with welding cables. Should I tell the guy I gave the $600 deposit to that it needed more work than he thought? I kind of think that it would have sold for what I have in it if it had been running? Dave
