TractorLinks.com
Re: dovetec corn stove
Dusty
12-11-2001 19:09:38
How large is this square hole? Could it be for a pilot light to show that the power is on?
The blower needs to be sized right to provide the right amount of air for the burner.
Dusty
Farmer /Paul
12-12-2001 04:15:29
 Re: Re: dovetec corn stove in reply to Dusty, 12-11-2001 19:09:38
I use a Dovetec stove to help heat my house. I am assuming you have a black stove. There is a combustion air blower on the left side behind a hinged door. It is a squirrel cage type blower, that supplies combustion air to the fire pot and cooling air to the exhaust stream. I can check for the model number off the fan and you may be able to purchase it from the supplier. (Dovetec is out of business) There is a Canadian supplier of corn stoves that may be able to help you to. A neighbour and I both use the stoves burning wheat,corn, or rye as fuel. Wheat being our fuel of choice.
Brian Bohn
02-11-2006 06:42:33
 Re: Re: Re: dovetec corn stove in reply to Farmer /Paul, 12-12-2001 04:15:29
I'm looking at buying a used Dovetec corn stove. The unit seems to be about eight to ten years old. The current owner has problems with the corn clumping up in the burn basin and starving the stove for oxygen and ultimately putting the stove out. The owner claims to have a moisture content of the corn at less than 15% and has put in a new auger from the holding bin to the fire bin. This model does not have an agitater in the fire bin like other models I have seen. Is there something else I should be looking at or is this simply what happens to the older models. thanks for any help anyone can offer.
Stephen Browning
12-22-2005 16:38:53
I was a salesman and repairman for the Dovetec Corn Stove that you are refering to. You can get any motor that is in the stove from GRAINGERS in Denver, CO.
Connie Harvey
01-08-2006 16:16:08
 dovetec corn stove in reply to Stephen Browning, 12-22-2005 16:38:53
We are new to the country and considering buying a second hand deovetec stove and apparently the auger is not working.
This could apparently be due to the thermostat, would you please be able to shed some light and suggestions as to what it may require?
It is going cheap and they claim all else works....but how would they know if the corn does not feed. Our gas bill was $600 this month, our first month here, and we need to do something, quick!
thanks a lot
Connie
Stephen Browning
01-09-2006 05:40:42
 Re: dovetec corn stove in reply to Connie Harvey, 01-08-2006 16:16:08
Hello again Connie, The auger being stuck is usually caused by something like corn stocks stuck in the auger. You can unhook the two wires from the auger motor, then remove the four nuts with a quarter inch drive, 9/16 inch universal joint socket. You can now pull the auger and motor out of the shoot. If it has a bind pulling it out, then you need to hace the hopper empty and then help the agugr where you see it in the bottom of the hopper. If you want to check to see if the aguer is actually stuck without taking it out of the shoot, when you unhook the wires, then hook a cord up to rhe wires attached to the auger motor, keeping them seperated, then plug the cord into a 110 volt wall socket of extention cord. You can watch to seeif the auger is moving in the bottom of the hopper. If the auger is not moving, then proceed, after unhooking the cord from the 110 volt supply, to remove the auger. Please let me know if that solves your problem. Thank you for the opertunity to assist you and feel free to contact me at homechief42@aol.com. I do have AOL IM.
Carleton Ingerson
01-09-2006 06:04:16
 Re: dovetec corn stove in reply to Stephen Browning, 01-09-2006 05:40:42
I also have a DoveTec corn stove here and I think that the gearbox on the auger is bad as it clunks and only turns intermittently. In another post you said motors were available from Grainger...Can you enlighten me as to which motor from Grainger I need??? Also how does the motor come off from the auger shaft?
Thanks
Connie Harvey
01-09-2006 06:29:32
 Re: dovetec corn stove in reply to Carleton Ingerson, 01-09-2006 06:04:16
I read from a forum that someone said the grainger motor fits.....I have written to grainger and I will let you know what they say.
Sorry I am not much help, I have not actually purchased this unit yet, pending on whether it is able to be fixed without too much headache.
Connie
Rodney Sparks
01-17-2006 13:32:46
 Re: dovetec corn stove in reply to Connie Harvey, 01-09-2006 06:29:32
I recently purchased a dovetech corn stove for $200. It looks to be in great shape. The reastat for the fans does not work and the auger does not turn. The auger motor however does work. Can I still buy parts for this stove?
I currently use a fisher wood stove. I have 6 inch double wall pipe run for my smoke stack. Can I use this for my corn stove ?
Carleton Ingerson
01-09-2006 07:09:04
Connie,
Sorry about that...I meant the reply for the other person. If you can get the auger fixed I would highly recommend the stove. Fantastic amount of heat and almost no waste.
Good Luck
Ron Kingdon
12-03-2005 08:06:30
Hi Just picked up a Dovtec, How do you get it to burn wheat??? My unit only works for about 3 hours on wheat? Thanks RJK
John W. Rylander
04-21-2004 20:50:40
I am looking for sometype of information on a dovetec cornburing stove. Just bought one and the fellow said that he had problems with the auger- is there anyone that can give me any information on where to get parts or a manual. I hear that the company is out of business- hopefully there are aftermarket parts that may fit. Thank you for any help that you can give to me.
John
Bud Ashton
02-18-2006 18:48:21
 Re: Re: Re: Re: dovetec corn stove in reply to John W. Rylander, 04-21-2004 20:50:40
I am also looking for parts for a Dovetec corn stove. It's a great stove and is about 15 years old, But I need a new fire box for it. Do you know where I can find one?
GEORGE HENNESSEY
12-04-2006 06:33:03
 Re: Re: Re: Re: dovetec corn stove in reply to Bud Ashton, 02-18-2006 18:48:21
I KNOW A GUY THAT SELLS DOVETEC CORNSTOVES I ALSO HAVE ONE IT WORKS GREAT KNOCK ON WOOD.... I WILL ASK HIM IF I CAN GIVE OUT HIS NUMBER HE CAN GET PARTS.... MY EMAIL ADDY IS TESTER400@HOTMAIL.COM JUST SO EVERYONE KNOWS THOUGH ITS ALL IN LONDON ONTARO ... IF INTERESTED IN THE NUMBER SEND ME A E-MAIL.. GEO..
Farmer/Paul
12-17-2001 17:59:48
The combustion fan on my Dovtec is a Dayton model 4c447, 1/20th hp., 115 volt,RPM1610, another number off the tag was E37403 , type U63B1. Made for the Dayton Electric Mfg. Co Chicago ... Hope this of some help.
