Hi T_Bone. Sort of a funny idea to offer you advice. I have a collection of advice you have offered on various subjects. I much appreciate your contributions to this board. Nevertheless, here goes. I don't think what you have in mind will work. First of all, trying to maintain the existing moisture in a new pressure treated deck is a losing proposition. The moisture content of newly created pressure treated wood is several times higher than the natural moisture content of the green wood it is made of. I believe no matter what you do, that moisture content will continue to drop. And the wood will continue to shrink until equilibrium with it's environment is reached. So as I see it, if you were to apply pickup bed coating while the moisture content is high, not only would you have a hard time getting it to adhere to high moisture content wood, you would soon find that the hardened bed liner material would be, in essence, bigger than the wood surface it is applied to and it will come loose. Although there is a certain amount of common sense in the idea of retaining wood moisture, in a climate as hot and arid as yours, it just isn't practical. I know this is true of furniture making. If I made you a piece of furniture here in east Texas, where the summer humidity is very high, no matter how well I finished it, it would soon develop cracks and space between joints, just sitting in your living room. Personally, if I were going to go to the amount of effort you are talking about, here's what I'd do. I would monitor the moisture content of the deck with a moisture meter. I would leave it be until the moisture content stopped falling. Then I would take up the planks and paint on a coat or two of Smith&Co. Clear Penetrating Epoxy Sealer (CPES). I'd soak the ends by standing the planks in a coffee can of sealer for a few minutes. I would follow this with an oil based (non-polyurethane) floor enamel with the highest UV rating I could find. As you undoubtedly know, protection from UV is the primary goal in your part of the country. I would let this age and weather for awhile. Then if you wanted to apply bedliner material on the load surface, you might actually stand a chance of it sticking and lasting for a good long time. In my opinion, the best part of your bedliner idea is the excellent UV protection you would achieve. Again, I want to thank you for your input on so many topics, I'm always interested to hear what you have to say. I hope my opinions are of some use to you. Michael
