Tool Talk Discussion Forum
Jacuzzi Air Compressor
Craig D
04-02-2005 21:30:08
I have a Jacuzzi Bros air compressor with a 10 gallon tank. The tank has a 1977 build date and I assume the compressor is of the same vintage as compressor, tank and motor all have the same paint and it looks like it was painted in 1977. The model number is SP3H331RP-S2/A and serial number 7L7135027. It is a two cylinder single stage unit with intake valve unloaders and a adjustable pilot valve to control working pressures. It has a Baldor L1408T 3 hp 1725 rpm 220v motor on it.
At any rate wondering if anyone knows much about the Jacuzzi Bros compressors. The business was sold to Regal Air Compressor at some point in the past and it appears Regal Air Compressor went out of business. Looking to find any specifications regarding the compressor.
Thanks,
Craig
Rocco
10-27-2005 11:17:15
 Re: Jacuzzi Air Compressor in reply to Craig D, 04-02-2005 21:30:08
Hello I have a jacuzzi air compressor model # SP6ZH331P/D serial SWJ with a 6.5 HP Kohler I was wondering if you had any luck finding specs Like CFM @ PSI Thanks Rocco
