Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Tool Talk Discussion Forum
cronacast 211
Ken Hortman
01-23-2005 18:02:20
“THE CAST IRON PROBLEM SOLVER”
Unquestionably the final answer to the most difficult cast iron repair welding. This highly sophisticated
alloy allows repairs that were previously impossible.
IDENTIFICATION: Printed Electrode, TIG Flagged One End
APPLICATION: AC or DC Reverse Polarity
CRONACAST 211 SUPERIOR ADVANTAGES:
• HIGH TENSILE WELDS IN EVERY TYPE OF CAST IRON, INCLUDING GREY AND
MEEHANITE; ALSO PRODUCES EXCELLENT STEEL TO CAST IRON WELDS
• CRONAMIG 211 IS FULLY MACHINABLE AND HAS A HIGH ELONGATION
FACTOR WHICH POSITIVELY PREVENTS CRACKING
• PASS OVER PASS WELDING WITHOUT SLAG REMOVAL BETWEEN PASSES
• ALL POSITION WELDING CAN BE DONE WITH CRONAMIG 211 WITH NO
DISMANTLING OF EQUIPMENT PARTS
TECHNICAL INFORMATION:
TENSILE STRENGTH: 70,000 PSI (483 MPa)
BRINELL HARDNESS: 185-240
OPERATING PROCEDURES:
Use AC or DC reverse polarity. Generally, where a narrow, thin
bead is desired a straight polarity application is suggested.
APPLICATIONS:
• GEAR TEETH • PUMP IMPELLERS
• SPROCKETS • CAST IRON TO STEEL
• PUMP HOUSINGS • CYLINDER BLOCKS AND HEADS
• BEARING HOUSINGS • TRANSMISSION CASES
• TURBINES • HYDRAULIC PRESS RAMS
CONFIDENTIAL MATERIAL, REPRODUCTION, IN WHOLE OR IN PART, PROHIBITED Printed in U. S. A. (Rev. 7/ 02)
PART
NO.
CW1035
CW1034
CW1033
CW1032
ELECTRODE
SIZE
3/32
1/8
5/32
3/16
AMPERAGE
55-95
75-110
120-150
140-175
COMBO PAC . . . . . . . . CW1725
PART NO.
CW1901
CW1902
CW1903
SIZES
CRONATIG™ 211T
1/16 x 36
3/32 x 36
1/8 x 36
CRONATRON WELDING SYSTEMS, INC.
CRONACAST ™ 211
CRONAMIG 211M-FC CRONATIG ™ 211T
PART NO.
CW2065
CW2066
CW2057
CW2058
CW2059
SIZES
CRONAMIG™ 211M-FC
.035 x 10 lbs.
.035 x 33 lbs.
.045 x 10 lbs.
.045 x 33 lbs.
.062 x 33 lbs.
WE 14 Corporate, Research & Distribution Hdqrs: 6510 Northpark Blvd. Charlotte, NC 28216-2367/ 800-843-0763/ www.cronatronwelding.com
