Tool Talk Discussion Forum
Replacement wheels for King Kutter finishing mower
Ken/KC
08-08-2003 19:19:58
I am looking to replace my wheels on my mower after fixing 3 flats.. in 1 day
Is there a foam filled alternative?
A solid rubber wheel like on the Brush Hog modle?
I checked at the Tractor Supply Store and all they wanted to do was sell me new wheel assemblies at $32 each
Any suggestions?
Ken/KC
08-17-2003 23:18:53
 Re: Replacement wheels for King Kutter finishing m in reply to Ken/KC, 08-08-2003 19:19:58
I finally found a tire repair shop that will fill tires with foam making them a solid tire for $20 a piece.
So I got them done. Place was called OK tire.
Ken/KC
TimV
08-09-2003 05:58:34
Around here, the ATV ice racers use a product called "green slime" for sealing tires with ice picks in them. You can take the tire off the rim, put in 50+ ice picks from the inside of the tire, remount it, put in a couple of cans of slime, and it will hold air. You may want to look into it--should be able to find it at any well-stocked ATV dealership.
Ken/KC
08-09-2003 14:40:26
 Re: Re: Replacement wheels for King Kutter finishi in reply to TimV, 08-09-2003 05:58:34
I did put the green slime in 2 of the tires, but was not sure how well it would hold. The original tires has a compound in them that did not seal very well. The one innertube had a hole in it that allowed the liquid to leak all over the inside of the tire and would not seal. I replaced that Tube and put the Green slime in it. If the Green slime will hold, great. Time will tell.
On another note, our local Goodyear tire dealer did not know what I was talking about when I inquired about foam filling tires.
My local John Deere dealer suggested a tire shop 23 miles down the road. Will check with them monday.
Thanks for the suggestions!!
Ken/KC
HappyKansan
08-08-2003 20:35:40
Some tire stores (Goodyear in our area) offer a service where a two part product is injected into the tire where it mixes and creates a type of foam rubber. This eliminates the need for air by making a solid core tire. You may want to check around and see if someone can do this for you. Good Luck!
Ken/KC
08-08-2003 21:04:09
 Re: Re: Replacement wheels for King Kutter finishi in reply to HappyKansan, 08-08-2003 20:35:40
Happy Kansan, Thanks that is the kind of info I was looking for, my John Deere has foam filled tires on the front and was wondering how they did it. I have a lot of thorn type trees around the edge of my property which is putting some large holes in the innertubes that the liquid sealer cannot handle
Ken/KC
Bill in TN
08-10-2003 10:29:43
 Re: Re: Re: Replacement wheels for King Kutter fin in reply to Ken/KC, 08-08-2003 21:04:09
Same question I have. I bought 4 new tubes and replace them a couple of times a year when they go flat. I really like my KingKutter, but wish they'd come out with an upgraded tire.
