How many gallons is a 20lb propane tank??
chris smith
02-08-2003 18:50:07
any one know?? I am using it for a portable tank and was curious as to how many gallons..
Thanks Again. Chris Smith
Andy
02-13-2003 23:28:27
 Re: how many gallons is a 20lb propane tank?? in reply to chris smith, 02-08-2003 18:50:07
Figure the internal area of the tank then divide by 231. ( 231 cu. in. = 1 US gal. ) Will work for figuring the gallons in any container. Volume of a sphere = cube of the diameter x .5236 Volume of a cylinder = square of the diameter x length x .7854.
Big Jake
02-11-2003 08:47:53
Link
Ray
02-10-2003 14:44:00
I used to sell propane at my store and I remember there being 4.3 gallons in a 20# bottle
Bill K
02-09-2003 07:28:48
The last time I filled my 20lb opd tanks, I got just over 4 gallons in each.
Paul Janke
02-09-2003 06:12:17
The question does not state actual capacity or rated capacity of propane. Propane is 4.24 pounds per gallon. The 20 lb rating leaves 20% of the tank empty to allow for the propane to expand when it gets warm. The tank will have water capacity (WC?) in pounds stamped on it, and I think that is 8.33 pounds per gallon.
Slowpoke
02-08-2003 22:10:54
I think most propane tanks have codes stamped in the guard that is around the valve. There should be a "W" with a number following. The number indicates the weight of water the tank holds. Seems like 8.5 lbs/ gallon of water, not sure. Then a 5 gallon tank would have "W42.5" on the guard. I can't find the article right now , but I believe it was in 'Trailer Life' magazine last year, maybe January or February discussing tanks becoming obsolete due to the old style valve. April 2002 was the deadline for filling the old tanks.
Ludwig
02-09-2003 18:05:39
 Re: Re: how many gallons is a 20lb propane tank?? in reply to Slowpoke, 02-08-2003 22:10:54
8lbs for a gallon of water, my grandmother taught me; "A quart is a pound the world around".
Brian G. NY
02-09-2003 20:19:04
 Re: Re: Re: how many gallons is a 20lb propane tank?? in reply to Ludwig, 02-09-2003 18:05:39
Actually, the old addage is: "A pint's a pound, the world around". Old time bakers figured a pint of flour or sugar weighed pretty close to a pound.
Ludwig - dang
02-12-2003 07:47:34
 Re: Re: Re: Re: how many gallons is a 20lb propane tank?? in reply to Brian G. NY, 02-09-2003 20:19:04
You're absolutely right, stupid keyboard. Always does what my hands say, not what I'm thinking...
thurlow
02-09-2003 18:49:21
Just how many quarts were in your grandmother's gallon?????
willie
02-08-2003 19:22:49
Chris
20#propane =5 gallon. 4 to 1 rario
Scott Green
02-09-2003 05:56:12
 Re: Re: how many gallons is a 20lb propane tank?? in reply to willie, 02-08-2003 19:22:49
Yes Willie , I'll back you on that one. When talking propane tanks , 20 pounds does equal 5 gallons.
Skinner
02-08-2003 20:20:38
I thought it would be a 7 gallon tank? Or is a 7-1/2 gallons = 30 #? Been a long time since I filled bottles.
