Andrew Curtis
New User
I'm new here and in a bind. I have a 1979 air compressor with a Wisconsin 4 cylinder motor. I have used this for the last 20 yes with no problems. I went to start it this fall and got no spark. It has a wico XH2207 magneto. I started looking into it and removed the rotor button before I realized it can go on more than one way.
I did put the flywheel at TDC compression stroke no 1 cylinder and the X on
the magneito showing through the inspection plug. I need to know where to put the rotor button.
Also I have spark coming from the coil. The magneto seems to be working ok I get a good snap when it fires and the shaft is tight and turns easy. The cap looks to be in good shape as is the rotor button. I'm going to do a little more work cleaning and testing and get back with follow up questions. Thanks for any an all help A Curtis
