Look up shows no replacement & no short block
Normally, for something like that it is because it has an electric PTO clutch & a 9 amp or 16 amp alternator (and they do not have a standard engine in that class that has that)
http://www.smallenginesuppliers.com/shop/html/pages/briggs_vertical_shaft_engines.html
Trying to find a replace for the posts title...The above quote, from the link, seems to say I am out of luck. Anyone know of a site that might have a replacement engine? Goes on a dixon 361..zrt...1992. thank you...
Original Engine:
283707-0117-01
Original Engine IPL (eParts)
Crankshaft:
693653Used Before Code Date 95080100
PTO Shaft Diameter
1
PTO Shaft Length
3.717
PTO Threads
7/16-20 UNF
Crankshaft:
693944Used After Code Date 95073100
PTO Shaft Diameter
1
PTO Shaft Length
3.167
PTO Threads
7/16-20 UNF
Replacement Engine Information
Replacement Engine:
NO REPLACEMENT ENGINE IS AVAILABLE
Replacement Shortblock:
No Replacement Shortblock is availa
