Let's talk LUCs
This message is a reply to an archived post by huntingreen2day2 on October 17, 2016 at 20:42:44.
The original subject was "Re: Lets talk LUCs".
If You Retard the Timing on the Magnito.. I will NOT Kick back... Its adjusted Wrong.. Larry
Spark should NOT happen at the spark mark when hand cranking. That is the running mark. When hand cranking the impulse should release, or snap at or very near TDC. Thus us cannot kick back when both timed and operating correctly. Then if you have the correct impulse coupling and if the points are correctly set spark will occur at the SPARK mark when running. I have never been kicked by my LUC.
