B S suction tube
Tom RS
For the old briggs motors that had the suction tube in the tank and the small copper line leading up to the carb., is it necessary to have a check valve in the tank?
Mine is toast.
I'm not sure if this will help you but what I did on an old 1936 B & S is to make a new line with a trap like a drain trap in it. 'this keeps gas or air from draining back to the tank. This old engine starts and runs good with this set up . Good Luck.
