huntingreen2day2
The above engine was running fine but was leaking oil into the gas tank. So I took it apart and installed new gaskets and oil pan bottom. I did not do anything else to the engine and now the darn thing won't start. It is not pumping fuel. I took the fuel line off and the check valve appeared to be ok. I could suck on the gas line and it would pump fuel. After many attempts and the engine not starting (it is not pumping gas) I bought a new fuel line assembly off ebay. The darn thing still will not pump fuel. The vent hole by the gas tank filler hole is open. I am at my witts end as to what the problem could be. I know it is fuel related because I can choke the engine or hold my thumb over the carb and it will not suck up fuel and wet. Any ideas? Thanks
