Economy engine 9hp
toot
Really need a ballpark value on this whole setup. Engine runs fine
Well let's see here. A 9hp Economy w/ drop center saw rig cart. Webster ignition and good fuel tank. You mention it runs fine. Are you looking at it to run slow at shows or to actually run to cut wood with it? I could see this selling at a decent auction that is well attended for somewhere in the $2000 to $3000 range. The saw rig will turn some off as well as the size. This thing will take up a pretty good sized footprint in the building. Real close to an area of a tractor or car. Something to look at while it is running is the main bearings to see if they are loose and then also the rod and wrist pin for noise. You might be able to get it for quite a bit less. If so, that is great. It comes down to whatever you and the seller can agree on and both be happy. It looks like a neat unit and would be a nice addition to any collection and display at a show. It would be a shame if it would get split up. I know I get a bunch of attention when running my 6hp Witte buzz saw rig at shows when cutting up wood. Have fun and best of luck.
