Larry in WNY
It's a 1952 hand crank engine with Wico XH1343 magneto. I bought it 20 years ago not running. Recently I rebuilt the carb, changed points & condensor, timed it per the manual, set all valves,tried adding oil to the cylinders to build compression. I have a backfire when first cranking which the manual says is normal for a cold engine. Then more cranking but no fire. I have a blue spark on all plugs. Then the carb will start dripping gas. I tried this with a fuel pump & without, but same result.
How hard should it be to crank? Without spark plugs it spins easy and with them slightly harder to turn. I can rotate with 1 arm and sometimes it gets harder and 2 hands are needed. I tried a compression check but it didn't build much & difficult to keep cranking it by hand.
I'm thinking compression is my problem as no gas seems to be getting to the cylinders. Any suggestions? Thanks.
Larry
Larry
