I have what I think is a burr mill. Cannot find a makers name on it. All the casting numbers are prefixed with the letter G. Old faded paint appears to be yellow with black pin striping. Very little paint left. No pictures, so I'll try to describe it as best I can. Machine has a 1 3/4" power shaft 48" long. On the shaft is a 8" wide 10" diameter belt pulley. Next is a 17" diameter 2 3/8 wide flywheel. Next is a 6" diameter 2 3/8 wide flat belt pulley with belt that pulls a 15 " diameter 2 3/8 pulley to operate a feed auger to carry grain to metal grinding disc. On top is a hopper 9" x 21" x 18" to pour the grain in to grind. All parts are cast iron. The machine base is 29" wide and cast iron. Machine probably weighs 300 to 400 pounds. The only thing I can find that may help is ( NO 3 ) on one of the castings. I assume this is the machine size. I know all would like to see a picture, but I don't have that ability. Any help with this would be greatly appreciated. Thanks
