TractorLinks.com
Stationary Engines Discussion Forum
Re: John Deere E 1 1/2 hp
Arnold Layne
06-23-2014 09:25:09
Any place that works on magnetos will have a magnet charger, the best ones charge it without removing the magnet from the magneto. If there are any shops around that rebuild starters and generators, these would be good places to check. Do you have a manual? The mag needs to be timed even though it just looks like a generator, on the JD's a strong mag can be out of time quite a ways but a weak one needs to be right on. To run your engine now you need a battery and a low-tension coil, and IF you run it this way the mag wire should be taken off the ignitor and grounded, NEVER feed current back towards the magneto. Fix your magneto.
