Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
Re: Hey Graygoat
greygoat
05-19-2014 07:52:21
I"ve never thought about doing it that way. I"ve
got about 14 Two cylinder engines here right now
and need to check all of them, since they have
been sitting over the winter. I checked my one V4
yesterday, and it was stuck...darn!, and I"ve been oiling them pretty regularly. I"ll guess
that now I"ve an excuse to try your idea.
The worry is,.....all of the 2 cylinders have
aluminum heads, and the allen wrench idea could
damage Spark plug threads.
Bernie/MA
05-19-2014 14:34:19
 Re: Hey Graygoat in reply to greygoat, 05-19-2014 07:52:21
I took the center out of a sparkplug and welded a short piece of pipe to it. Drilled a shaft that would slide into the pipe and pressed a slice of socket-head bolt into it so the allen wrench couldn't spin and used an old tappet spring over the shaft. Bolts welded to the outside of the pipe connect to a plate on top of the spring. Unbelieveable how good it works.
Duner Wi
05-19-2014 09:47:47
Open up an anti fowler with bigger hole in center. Insert allen , screw in anti fowler. That should save your threads.
I have loosened up stuck valves in Ford and Chrysler flatheads using the "L" shaped tool. Tap lightly, no pounding. Have fun!
Copyright © 1997-2015 Yesterday's Tractor Co.
