Yesterday's Tractor Co.
Shop Now View Cart
Stationary Engines Discussion Forum
Re: generator runs now but had no govenor!
12-29-2013 16:20:00
As a rule, generator engines were not made to idle. Since most power consuming devices require 60Hz AC current, the generator is designed to run at (usually) either 3600rpm or 1800rpm. Running at slower speeds gives incorrect frequency.
12-29-2013 19:20:49
 Re: generator runs now but had no govenor! in reply to jimg.allentown, 12-29-2013 16:20:00
This think was like out of control revving out but stupid me after I looked at it the governor lever was loose on the shaft. Not totally sure how to set the governor but I put it in wide open position and then put the carb in wide open position and tightened it down. Now it's running a bit over idle with nothing hooked to it
