Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
Re: Still
huntingreen2day
12-20-2013 16:23:33
I made a long punch to go from the backside of the flywheel and punch the pin out that holds the handle in. Mine was made out of like 5/16 rod and ground on a bench grinder about 1 inch back at a taper with the small end being able to fit in the pin hole and punch the tapered pin out. Install the spring over the handle and then drive your pin back in. It is a tight fit on the backside of the flywheel but you can do it. I have done several.hope this helps.
Bob Harvey
12-22-2013 08:32:33
 Re: Still in reply to huntingreen2day, 12-20-2013 16:23:33
Thanks. The part that has me confused is; which way does the spring go ?
