TractorLinks.com
Stationary Engines Discussion Forum
Re: Honda clone generator backfiring through carb, any ideas?
JT
12-08-2013 15:11:04
If it is backfiring out the carb, a couple things, burnt intake valve if it does it every time, or could be carb contaminated. I know, new carb, but, unless you took tank off and completely flushed it, could still have bad fuel
RBOOE05
12-09-2013 03:30:15
 Re: Honda clone generator backfiring through carb, any ideas? in reply to JT, 12-08-2013 15:11:04
I was concerned that maybe the fuel had water in it so i put some of that heat in the tank to remove water and help clean the lines but still didnt help. I think im going to start over and try new gas from another station and im going to pull the flywheel to verify the key is still ok and after that i think ill have to pull the head.
JT
12-14-2013 10:26:28
 Re: Honda clone generator backfiring through carb, any ideas? in reply to RBOOE05, 12-09-2013 03:30:15
also check and make sure the push rod or rocker arms is not bent, or broken or a valve stuck in the huide, another thing that the chinese engines do
