Anonymous-0
Hi all, i picked up a non running chicago electric generator with a 5.5 hp honda gx160 clone engine. I could not get this thing to start to save my life, found a weak spart and a broken air screw on the carb. I replaced the plug, coil, and the carb and now after about an hour of messing with it it fired up and ran really well. I shut it off and started it again with the choke on a few times no problem. Next day i go out and back to square one. I even sometimes get a nice big flame shoot out of the carb so that tells me maybe valve? Opened up the valve cover and re set the valve lash and i see both open and close and seem to be working fine. Checked air screw on carb and its 1 1/2 turns out like should be from what i have seen. Everything is tight no air leaks or anything. Anyone seen this before? Am i over looking something? Thanks a ton!
