Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
Re: Wisconsin engine clutch
greygoat
10-14-2013 08:56:35
Generally, most 2 cylinder engine clutch"s will
interchange...but you need to have an engine
that"s set up for a clutch,,that is..drilled
and tapped, and the correctly machined crankshaft.
4 cylinder engine clutch"s WILL NOT fit on 2 cylinder engines, the bolt spaceing, of the
housing assembly is different.
JOB
10-14-2013 17:24:31
 Re: Wisconsin engine clutch in reply to greygoat, 10-14-2013 08:56:35
I knew on the early 50's VE's, VF's and VP's the crankshaft and block was machined or drilled differently for a clutch.
The clutch on a VH looks different from the ones on the older models. To be more specific would the clutch from a VH4 work on another VH4 that did not come with a clutch from Wisconsin? Would the clutch from a VH4 work on a VE4?
Copyright © 1997-2015 Yesterday's Tractor Co.
