TractorLinks.com
Stationary Engines Discussion Forum
Re: Wisconsin VH4D bench start
JOB
08-24-2013 19:08:06
I read you post wrong. ElToro is pointing you in the right direction.
The shop most likely timed the cam to the crankshaft correctly. As ELToro is pointing out the Magneto was not timed correctly to the engine. The page as I see it that Eltoro posted is hard to read. There is a Wisconsin web site you can go to and get the manual to correctly time the Magneto to the engine. That is what I feel is your problem.
If your Magneto had spark you did not need to have it repaired.
scott rollins
08-25-2013 03:10:39
 Re: Wisconsin VH4D bench start in reply to JOB, 08-24-2013 19:08:06
I accidently ran a hot wire to the mag and fried it for sure I had it tested. I found the manual and the timing should be set correctly when I get the mag back it should fire up.
