TractorLinks.com
Stationary Engines Discussion Forum
Re: Wisconsin VH4D bench start
El Toro
08-23-2013 18:39:38
Bring No1 piston to tdc on the compression stroke.
If your mag is installed your rotor should be pointing to the No1 plug tower that's about 2 o'clock. Here's a pic. Hal
scott rollins
08-24-2013 03:00:55
 Re: Wisconsin VH4D bench start in reply to El Toro, 08-23-2013 18:39:38
Thanks, I will print and use this, when I found or at least thought I found TDC once before I hold my thumb over the number 1 plug hole turn the enging over until I felt pressure like the book said but do I only do that until the X on the fan fin is center of the cover? That's what it say's to do but I only felt a little pressure on my finger? How do you know your at TDC at the most pressure point during the turning of the engine or just after the pressure reaches the most and then "click" ? And should I worry about where the X is on my fan fin? It says TDC of fan cover but I would amagine TDC of piston matters more? By the way Magneto is being rebuilt now so I'm down for a week or so.
