TractorLinks.com
Stationary Engines Discussion Forum
Re: Wisconsin VH4D bench start
teddy52food
08-17-2013 11:54:37
Take all the plugs out and turn it over by hand with a finger or thumb in a plug hole. Mag should snap at the end of each compression stroke. If it doesn't, change the wires until it does.
El Toro
08-23-2013 18:31:43
 Re: Wisconsin VH4D bench start in reply to teddy52food, 08-17-2013 11:54:37
The rotor should be pointing to No1 in this picture if you have No1 piston TDC on the compression stroke. Hal
Scott rollins
08-17-2013 12:06:05
Tried the thumb over idea and I have compression at each cylinder , double checked timing, but have no spark from the magneto, I'm just going to get a new mag, points, rotor, condenser and that should be it?
JOB
08-17-2013 13:58:20
 Re: Wisconsin VH4D bench start in reply to Scott rollins, 08-17-2013 12:06:05
Make sure points are set at .015 and disconnect the grounding wire from the magneto and check for spark. You may have to take light paper and clean up the points.
Scott rollins
08-17-2013 14:25:10
 Re: Wisconsin VH4D bench start in reply to JOB, 08-17-2013 13:58:20
10-4 thanks
