AENL Wisconsin Crank Seals
Dalex
Would anyone have a modern part Number for them ? Like in Nat'l , NAPA or C/R ?? My manual only shows the old cork seals.......... Thanks !
IF you can get accurate measurements, a bearing supplier may be able to help, or any 'Good' parts house. HTH
I"ve done that on Wisconsin 2 cylinder engines,
by measuring the OD,(Outside Diameter) of the
crank. and the OD, of the sheet metal retainer that holds the cork seal. The Old gasket sets used the cork seal. I recently purchased a new
(Fel-Pro) set from NAPA Auto Parts, that had a
Metal/Rubber seal. Someplace I"ve got notes on what size fits 2 cyl engines, but nothing on 1
cyl engines. And I looked in the Wisconsin master
parts book, and the cork seals have different part
numbers.
Ok guys here ya go. On the net ,Rock Creek Consulting, 814-766-3675, [email protected] has the gasket set ( Q60 )and the seals for a very modest cost. The G. set doesn't have a COO, so we know what that means. The seals for the std engine where both are the same are P/N 12391 in SKF. Now four of us will be able to provide P/N's in the future !
