I think the answer is no but want to make sure.
Will the distributor from a VG4 work in a VH4.
Will the distributor from a VH4 work in a VE4. I
had heard the VH is even fire and VE is odd fire so
I would think that would make a difference????
In the manual it says a VG magneto will not work
on a VP. I put a VG magneto on a crank start VP It
started on two cylinders and by moving spark plug
wires I was able to get it to hit on all four.
I pulled the heads off a VG4 today because the
spark plugs did not want to come out without extreme
force. I have those upside down now soaking with
liquid wrench.
When I took the heads off I noticed that on a
couple of head bolt holes under the exhaust
manifold the the top half inch of threads were
gone. These bolts came out with ease so that did
not happen when I removed the head. Any ideas on
how that could have happened?
liquid wrench.
