Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Stationary Engines Discussion Forum
Re: Wisconsin engine question's
Duner Wi
05-29-2013 18:01:03
This might help, not certain if all VG4 were even fire. All I ever worked on Were VE4,VF4 VH4. If you have a distributor drive it should be 1/2 speed . I revolution of rotor for 2 revolutions of crankshaft. WI magneto’s were most or all full speed. One revolution of MAG for 1 revolution of crankshaft. http://www.smokstak.com/forum/showthread.php?t=76987
JOB
05-30-2013 04:15:21
 Re: Wisconsin engine question's in reply to Duner Wi, 05-29-2013 18:01:03
I read your smokstak thread and am still confused, except for the part where it says you can not interchange a half speed distributor with a full speed distributor. I would think if you changed what ever is in between the distributor and the idler gear at the same time the distributor would work????
I am trying to modernize a 1965 vintage VG4 to electric start. The parts I am planning on using are coming off an older VG4. The older VG4 has the 3 inch round holes in the sheet metal at the back of the engine so you can clean out schaf from around the cylinders. That is why I think it is older.
